Any recommendations on LED conversion kits?
I see there is pre ballast options (directly to 12v plug) and regular plug to ballast output.
Also, any experience with the fitting in the headlight casing and cap?
LED headlight conversion kit ?
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
It's hard because the headlights were never designed with LED's in mind. There is a metal or plastic hat on the top of where the bulb would be that is blocking the very tip of the bulb, even restricting size, and I believe most LED's have their lights on the tip, so you'd have a situation where your light will bounce around all over; including the fact that the shape of the headlight are only meant for incandescent. And then you have to remember that the Ford wiring will always have electrical gremlins, so eventually your H11 sockets will melt.
So no, I wouldn't recommend any LED's, but if you're still insistent I'm sure others will chip in.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
I have a P3 volvo not a P2 but I did upgrade to LED Headlights to GTR Ultra LED 2.0 bulbs
I did have to mount the Driver Module to the inside of my Headlight housing
viewtopic.php?f=31&t=87687&start=140
These Bulbs completely transformed my headlight
From -> barely acceptable
To -> equivalent to factory HID headlight
Good luck
Paul
Good luck
Paul
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
I just tried LED bulb replacements and got a bulb failure warning (08 S60), so you'll need to account for that if you don't want to clear the code each key cycle.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- 1191 Views
Last post by nyc1836
- 11 Replies
- 2729 Views
Last post by MrAl
- 3220 Views
Last post by Canadian Moose
- 3178 Views
Last post by callahanoffroad
- 544 Views
