1998 1999 2000 9444207 Hood release cable, Volvo,push pull control mechanism
Has thanked: 1609 times
Been thanked: 4065 times
How not to remove
Two m6 10 mm bolts hold the handle to the side of the car, release the white metal pulling up. Now you can remove the black plastic clip,and un hook the cable from the handle.
Half done
Under hood, I removed theee M6 bolts and then removed the cables with thin nose pliers
Now you can forget the size of the assembly and think you can just pull it through the firewall into the engine room?
https://www.fcpeuro.com/products/volvo- ... escription
It gets stuck there and your hour of life is now wasted, go outside and go yell at Clouds.
