premium sound system (815 model) Topic is solved
SirBrickWagon
- Year and Model: 1997 Volvo 850
- Has thanked: 7 times
- Been thanked: 11 times
hi all. new problem with the wagon. got a premium sound system for it, but the CD player's scratching my discs. makes a weird sound when it's in. any solutions?
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
SirBrickWagon
this is of utmost importance, i scratched my kanye CD
- Has thanked: 2198 times
- Been thanked: 1851 times
Are you sure there is not a 2nd CD in there? I had that once with a unit I got from Pick and Pull. For some reason the unit allowed 2 to be installed. Otherwise it may have damage to the laser carrier.
If you are stuck PM me and I can loan you a SC-816 and have a look to see if there is anything obvious to your unit.
SirBrickWagon
when i press eject it says NoCD, it played CDs fine for a while but then it gradually started scratching them. makes a weird noise when i load it in, sounds like scraping every maybe split-secondscot850 wrote: 07 Feb 2022, 17:41 Are you sure there is not a 2nd CD in there? I had that once with a unit I got from Pick and Pull. For some reason the unit allowed 2 to be installed. Otherwise it may have damage to the laser carrier.
- Has thanked: 2856 times
- Been thanked: 1332 times
Is the scratching on the disc circular? Can you post a photo?
SirBrickWagon
it sure is. can't attach a photo but it's definitely circular.
Ok it's not an inject/eject surface that's scraping. At least you'll know where to look. I'd pop it out at take a look.
SirBrickWagon
pop it out and take it apart a little to have a peek?matthew1 wrote: 07 Feb 2022, 19:43 Ok it's not an inject/eject surface that's scraping. At least you'll know where to look. I'd pop it out at take a look.
Yes. There are two swivel arms on each side. Pop them out and pull.
SirBrickWagon
hopping out to my car quickly to go grab it. will keep you updated.matthew1 wrote: 07 Feb 2022, 20:09 Yes. There are two swivel arms on each side. Pop them out and pull.
- 1542 Views
Last post by azureblue
- 6113 Views
Last post by izzys40
- 3479 Views
Last post by Oldsguy
- 3303 Views
Last post by geirmeister
- 734 Views
Last post by cn90
