I am trying to replace the valve stem seals, and I might lap the valves. I have the head off since I am replacing the head gasket. How do I remove the valves? Would this tool: https://www.harborfreight.com/universal ... 60335.html
from harbor freight work?
How do I take the valves out of the head?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
See if this helps.02V70 wrote: 07 Feb 2022, 11:02 I am trying to replace the valve stem seals, and I might lap the valves. I have the head off since I am replacing the head gasket. How do I remove the valves? Would this tool: https://www.harborfreight.com/universal ... 60335.html
- Has thanked: 312 times
- Been thanked: 818 times
That HF tool will not help you.
People use the Schley 91400B to do this in the car (or knock-off equivalent) but you can presumably also use a clamp compressor out of the car - I am not familiar with that but it is done in the video from jones there. You need the special adapters like in the video. Likely you can buy what you need from this link but you'll have to piece it together https://www.amazon.com/s?k=SP+Tools+914 ... nb_sb_noss
- jonesg
From the 1000 reviews, important tip.
"This tool worked perfectly to compress the valve springs on the heads from a 5.3 V8. I was hesitant to purchase this tool after other reviewers said that it would bend or spread open, but I had no issues. I did use a socket and hammer to tap each of the retainers before trying to compress the springs, if I had not done that, it would have taken much more force to break the retainer free from the keepers and may have resulted in the tool bending. It took a while for me to remove the springs from the first head, but once I got the hang of it, it only took about 10 minutes to remove all 8 springs from the second head."
- 16 Replies
- 2444 Views
Last post by tryingbe
- 962 Views
Last post by durk80
- 1052 Views
Last post by natural4reelz
- 699 Views
Last post by HerrGruyere
- 649 Views
Last post by Earn_est_89
