Excessive rear tire wear
- csh
- Year and Model: 2004 S60 AWD
- Has thanked: 5 times
- Been thanked: 3 times
My 2004 S60 AWD seems to have developed a problem with excessive tire wear in the rear. Last time I checked both front and back tires were relatively close in the amount of wear. Now there is a significant difference. The wear across the tread is fairly even with no excess wear on either the outer or inner edges and no cupping or scalloping. It looks like I am going to have to kick a car out of the garage and get this one in to check the rear toe and inspect the trailing arm bushing. Given that I don't see anything with the wear pattern that would suggest an alignment problem I am a bit surprised to see the rear wearing more than the front. Along with the tire wear I have noticed that the rear tends to get a bit squirrelly when going over certain bumps. Is there anything else that I should look at as a part of checking for possible culprits?
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Too many burnouts in the street with the kidz yo.
I would think toe would lead to cupping. Too much negative camber wears out the inside tread fast. Too much air pressure will leave a worn spot down the center, not enough will wear out the sides.
Are they the same tire front and back? The rears aren't a much softer compound? Is something bent in the rear?
- csh
Same tires front and back. It is an AWD so I prefer to replace all 4 at the same time. Unfortunately, I won't be able to investigate this weekend so maybe next weekend. I'll check the inflation this afternoon, but it should be 38psi or less. If I fail to find anything obvious when I investigate, I think I will rotate the tires to confirm that the rear is wearing faster. There is a chance that I am remembering things wrong about the amount of front vs. back tire wear but I don't think so.
- 12 Replies
- 4329 Views
Last post by lous_97_850
- 11 Replies
- 2514 Views
Last post by icrashcars
- 1456 Views
Last post by oragex
- 5668 Views
- 1915 Views
Last post by oragex
