Difficult to start in cold weather.
Year and Model: 1998 S70
Post by 862132 »
Hello, I own a 1998 S70. When the temperature reaches around 30 degrees Fahrenheit it will not start, but around 50 degrees Fahrenheit, after constantly attempting to start, I hear a humming sound over the dashboard on the left near the speaker area. New fuel pump so that’s not the issue. Any help or suggestions? Thank you.
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
What is the battery voltage at on standby and under crank. Does it make a difference if you turn all the lights and heater off when cranking?
Can the car be jumped?
If its not voltage, and fuel pump is new then look at the spark.
When were your sparkplugs changed? Are there any stored codes? Does it have a rough idle?
I went through a very rough idle and sometimes inability to start which was solved by clamping the terminals on a good battery properly (gotta hammer those suckers down to fully nest on the battery terminal), cleaning my idle air control valve which helped with the idle about 30-40%, and changing our my cap and rotor (the contacts were worn out inside).
Hope it helps.
2008 S60 2.5T Auto (Sold)
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Check your fuel pressure to make sure you're getting adequate pressure at the rail. You could have a shiny brand new bad pump, or a wiring issue.
What prompted the new pump? The current issue, or something else?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1609 times
Been thanked: 4064 times
…. And what was the source and brand of the pump?
