I cant get the valve stem seals out.
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I tried getting the valve stem seals out with some needle nose players as described in a tutorial video I watched, but they wont come out. It just breaks into pieces. I ended up tearing the top of the valve stem seal off I ended up with this:
How do I get it out now?
2002 v70 X/C 288k miles
Has thanked: 1609 times
Been thanked: 4064 times
I would go after it with a bent pick
02V70
Post by 02V70 »
abscate wrote: 15 Feb 2022, 19:02 I would go after it with a bent pick
Also how would I get the rest of the non-broken valve stem seals out?
Edit: It turns out we don't have one. Any other ideas?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Hold it with an ice pick, thread a wood screw in and yank it out.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Wait, you need special pliers in order to take them out.
02V70
Post by 02V70 »
vtl wrote: 16 Feb 2022, 14:09 Wait, you need special pliers in order to take them out.
would something like this work
https://www.amazon.com/HW0107-Valve-Stem-Pliers-Removal/dp/B09174LG1V/ref=sr_1_9
02V70
Post by 02V70 »
Also, is there a way to remove the metal that surrounds it?
vtl
Post by vtl »
Yes, those would work.
It looks like your engine was overheating and the seals were cooked and are hard to take out now. Thus, you'll still have hard time removing them those pliers. I recommend rotating them slightly CW/CCW, then wiggle a bit and pull out. Eventually they'll come off.
Not sure, what metal? Metal is a part of a seal?
02V70
Post by 02V70 »
vtl wrote: 16 Feb 2022, 19:03 Yes, those would work.
I thought that the metal on the outside was not part of the seal, so I was trying not to damage it with the plyers. I just figured out it is part of the seal... Much easier now
andybuzz2u
Year and Model: 2005 S60
Post by andybuzz2u »
They make a special pair of pliers for the job. Seal removal tool. You need something like this for any new engine work on any brand, https://www.ebay.com/itm/153390107914?_ ... %3A2563228
