Where to find a fuel Sending unit
BooRadley
Year and Model: 92 - 740
Post by BooRadley »
92 wagon 740 non turbo.
Im fairly certain it has the "regina" system not that I know what that is. Google is of little help defining what rex regina is and the same with locating this part.
Thanks for any help.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
See if any of these are any help -
http://www.voluparts.com
This site lets you drill down to your exact car and then system. There are parts diagrams to help you see what it all looks like -
https://www.volvopartswebstore.com/cars ... parts.html
BooRadley
Post by BooRadley »
BlackBart wrote: 16 Feb 2022, 11:24 See if any of these are any help -
Thank you.
I found so other parts that I will need like taillight lenses. The sending unit is elusive.
BlackBart
Post by BlackBart »
FCP page for '92 740 NA "fuel sending unit" -
https://www.fcpeuro.com/Volvo-parts/Fue ... ding-Unit/
<EDIT> They're not showing a pic here, but you could hunt around using these part numbers and see if it matches yours.
https://www.fcpeuro.com/products/volvo- ... 40-3501047
BlackBart
Post by BlackBart »
Look like this one?
https://www.ebay.com/itm/175135792768?c ... gLmnfD_BwE
I found some forum references to Regina vs Bosch systems.
https://volvoforums.com/forum/volvo-240 ... lvo-54961/
BlackBart
Post by BlackBart »
"Rex Regina vs Bosch Engine Management Differences:
"Rex/Regina is an engine management system that handles both ignition and injection, and was designed by Bendix. It's not difficult to tell what system you have, as the most clearly defined feature of the Rex ignition system is the giant transformer on the driver side shock tower. This transformer sits on top of a control module and makes up the ignition coil for the system. This is in contrast with the standard Bosch ignition coil that looks more like a tin can."
BooRadley
Post by BooRadley »
BlackBart wrote: 16 Feb 2022, 11:37 FCP page for '92 740 NA "fuel sending unit" -
That fits an 1987 Volvo
When you search for a 1992 the rubber sending unit ring is all they have. The Ebay unit is for a 1990 and it has 4 inlet tubes. Mine has only 3.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Assuming the 740 is similar to the 240 and I think they were very similar, the fuel sender unit should be mounted on top the fuel tank. It is integral with the fuel pump. You may have a cover plate you can remove from the floor to reach the top of the fuel tank without removing the tank. This information is from the Bentley Service Manual for 240 1983 to 1993.
I do not think the ignition system brand has any impact on the fuel sender.
BooRadley
Post by BooRadley »
volvolugnut wrote: 16 Feb 2022, 19:07 Assuming the 740 is similar to the 240 and I think they were very similar, the fuel sender unit should be mounted on top the fuel tank. It is integral with the fuel pump. You may have a cover plate you can remove from the floor to reach the top of the fuel tank without removing the tank. This information is from the Bentley Service Manual for 240 1983 to 1993.
Hi
Thanks, I have the old one out. It looks like the 740 does not work in the 240.
https://www.ebay.com/itm/173831118197?m ... olid=10050
Is the sender damaged or corroded? if corroded, you may be able to clean it with carb cleaner and a brush.
