Protecting fuel lines from engine heat Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
After another break-in drive yesterday, I was under the hood checking temperatures, and noticed the the fuel lines get pretty warm as they pass over the engine. Makes sense, as they are sitting between the top of the engine and the heat blanket under the hood.
On top of that, to make things worse, they are painted black. But typically you want your fuel cool, not hot.
Has anyone tried to shield these lines in order to keep the fuel as cool as possible ? Seems like it would be easy enough to do, so I'm going to try an idea or two today.
1999 V70 GLT
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
No need for that...it came from the factory like that and no further isolation is needed.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
I agree that it probably isn't necessary, however if you want to add some sort of shielding, I would probably use that reflective aluminum wrap, similar to what you see on AC and power steering lines.
Has thanked: 1848 times
Been thanked: 1710 times
If you can get some of the shielded wrap like the guys suggest it may help. I once managed to get a roll of shielded tube like aluminum coated heat protectant that was to put over fuel lines. No idea where I got that though.
Sveedy
Post by Sveedy »
Well it seems like cooler gas would get you more " bang " for the buck, and it doesn't seem like it could hurt.
Yes the metal HVAC tape was what I was thinking of using. Specifically I was going to wrap the lines with a layer of tape, then slip a length of heater hose over that, and then do a second wrap of the tape over the hose.
I'm mainly thinking that this won't hurt on those occasions when I'm driving in the desert in 118* temps. I used to have issues with my work truck vapor locking in hot weather, and after wrapping the lines, the problems all but went away completely. But I realize this is a completely different beast.
1999 V70 GLT
You definitely have more high temp issues that most of will see, so I don't think it can hurt to try to reduce fuel temps and possible vaporization issues. I only have to deal with -40+C to +35C temps!!
Sveedy
Post by Sveedy »
Well this is the result.
I decided that the outer layer of tape wasn't necessary ( yes I realize that none of it probably is ), and might not look very nice.
This I can deal with.
1999 V70 GLT
That almost looks like it should have been stock!
Nice job!
Sveedy
Post by Sveedy »
Thanks Scot ! I kind of thought the same thing when I was done. With all the other hoses over there, it just sort of blends in.
Only took about 30 min or less to do it, and logically it should be a positive improvement.
1999 V70 GLT
bmdubya1198
It could only be an improvement, it certainly won't hurt anything. Nicely done!
