Starter Motor Life?
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
I may have posted awhile back something on this topic and another member had responded by stating to try and turn the key to the accessory position twice and then turn the key fully to start the engine.
This seems to work lately and I just wondered if my starter motor is on it's last leg.
My P2 has 173k on her and I recently replaced both the alternator and the battery. Any opinions?
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
This video below helped me diagnose my starter. The POS-II twice thing is odd to me. You need to do that in order to start the engine? The only thing I can think of doing that for is maybe to prime the fuel and vacuum pumps? Do you have fuel pressure at the rail when you let it sit overnight?
04s60 2.4
04xc70 2.5t
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Mr. Detail wrote: 08 Mar 2022, 08:54 I may have posted awhile back something on this topic and another member had responded by stating to try and turn the key to the accessory position twice and then turn the key fully to start the engine.
Check fuel pressure in the ramp, it could be a weak fuel pump.
Mr. Detail
How do I do that? Check the pressure in the ramp? Special tools needed?
vtl
Post by vtl »
Mr. Detail wrote: 09 Mar 2022, 06:27 How do I do that? Check the pressure in the ramp? Special tools needed?
Yes, Schrader valve on the ramp. Something like that is needed: www.amazon.com/BETOOLL-0-140PSI-Injecto ... 00VV29NHM/ Can get one at Autozone, etc.
Fuel pump primes the pressure when key is in position II. Engine needs 400 kPa of pressure to start (and work).
Mr. Detail
Thanks much vtl!
Has thanked: 1609 times
Been thanked: 4063 times
Do you need two turns of the key to CRANK or two to turns to START ?
First is a starter problem, second likely fuel delivery problem.
At 150,000 miles, it’s a hood time to clean out the pcv system on a P2. When you do that , the starter is a5 minute removal. Take it to an auto electric shop and have it rebuilt for $100
Repeat every 10 years
Mr. Detail
I turn the key to the accessory position twice to start or turn over the engine.
Mr. Detail
If it is "fuel delivery" does that mean a dying fuel pump?
vtl
Post by vtl »
Mr. Detail wrote: 10 Mar 2022, 05:54 If it is "fuel delivery" does that mean a dying fuel pump?
Either that or fuel pressure damper. Very old fuel filter can be clogged, too, but given the age, my bet is on fuel pump.
