I have a 2016 V60 and I've installed a questionable Android head unit -- it works mostly but the canbus integration isn't the best. The biggest issue is that when I adjust the car's internal temperature controls, it doesn't decode the information properly and won't tell me what I've set the temperature to.
I know that there are 20 steps, and that the lowest temperature setting will just say "low" instead of the numeric temperature in degrees. Do any of you know, or would you be willing to check what the actual numeric range is for your temperature controls? Just so that when I need to set the temperature to a specific number I can start from low and then move up however many steps I need to.
Thanks much
Temperature control range question
- 439 Views
Last post by Gymbo
- 1301 Views
Last post by Sommerfeldt
- 4710 Views
Last post by EChem
- 13 Replies
- 2449 Views
Last post by ferocity02
- 14 Replies
- 7198 Views
Last post by BEJinFbk
