bad idle '94 940 Turbo wgn automatic
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Regis
Post by Regis »
My 94 940 turbo wagon (automatic) has 171,000 miles and is idling oddly. When I start the car and it is cold (MN) the engine idles then dies. I then restart it and give it gas and begin my drive to work and at stops it will begin to idle low then high then low then high working itself in this loping fashion then it dies. I restart and continue on, putting the car in nuetral at stops and giving it gas. About 7-10 minutes into the commute the problem goes away. Please help...
Thanks
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
There are several possibilities for bad idling. I suggest that you read the fault codes and post the results so we can help you further.
If you don't know how to read the fault codes check:https://www.matthewsvolvosite.com/chat/p ... 08&start=0. Go to page 2 and scroll down.
This is headed 740 but applies to the 940.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
