Mystery Hose Clamp
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I am doing a head gasket job, and I am now putting the intake manifold on. How many hose clams connect
This:
to this?
Past me put a hose clamp on both the intake manifold and the pipe. If its just one that connects them like I thought, then I probably thought the hose clap that I put on the intake manifold when I stored it was the one that I left on the pipe.
Does anyone know what it could be for?
Here is a photo of it with a razor blade for scale.
Its not the one for the air box or that long pipe that goes into the turbo.
It is also entirely possible that the hose clamp was a random one lying around that I thought went in the volvo.
2002 v70 X/C 288k miles
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
The first pic is the correct one. I flip mine so you can reach the 7mm screws from the vantage point of the starter/air box.
Make sure you shove that plastic pipe up onto the TB (ETM) real good.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
Has thanked: 1609 times
Been thanked: 4065 times
That’s not a Volvo clamp. Use the right ones on turbo induction because these are under a lot of pressure. When they pop off , it’s a bad day.
Here’s the P80 version from the Volvo parts web store
viewtopic.php?p=517348&hilit=Induction+clamp#p517348
02V70
Post by 02V70 »
abscate wrote: 17 Mar 2022, 03:31 That’s not a Volvo clamp. Use the right ones on turbo induction because these are under a lot of pressure. When they pop off , it’s a bad day.
So do they have to be tightened more than the others?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
On a high pressure turbo, the air tubes need to have clamps tight. I use a 1/4 inch ratchet with socket instead of a screwdriver.
If not tight, they can blow off when the turbo pressure rises. Then the car dies or goes into limp mode without any power.
02V70 wrote: 17 Mar 2022, 10:07
The Volvo ones have that funny outside ring that firm up onto the inner band when correctly tightened
I don’t think there is a torque spec for those in VIDA but we will check. Use a socket, 7mm, not a screwdriver , so you can feel them firm up.
