Does my engine sound normal.
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
Here is a short video that shows how my engine sounds. (it is in a 2002 V70, and it runs on Gasoline)
https://drive.google.com/file/d/1jh3Y0oFqZBTwViRw1vFL-SdZTPHwWiU5/view?usp=sharing
It sounds a bit too tappety compared to other engines. It gets faster and quieter when I rev the engine.
Is this normal? If not, does it indicate any problems?
I also just reassembled everything after replacing the head gasket.
2002 v70 X/C 288k miles
Has thanked: 2215 times
Been thanked: 1853 times
I can't recall if the 02 P2 engines have hydraulic or solid lifters. If they are hydraulic then they may have drained and not re-filled.
What oil are you using in terms of viscosity? 5W-30 or what?
02V70
Post by 02V70 »
I am pretty sure it has solid lifters, and it has new 5w-30 in it.
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
Sounds like a pulley. When was the last timing belt change? If not the timing then you may be a bit more lucky with the accessories. This is just my guess.
02V70
Post by 02V70 »
The last timing belt change was 65k miles ago. However, I did take it off and put it back on when I was changing the head gasket.
02V70
Post by 02V70 »
chris11211 wrote: 22 Mar 2022, 15:46 Sounds like a pulley. When was the last timing belt change? If not the timing then you may be a bit more lucky with the accessories. This is just my guess.
I listened to it again, and it sounds like its coming from under the cam cover, or maybe the fuel injectors, so I don't think its a pulley.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Ticking noise is ok for these engines. Tappets are loud, injectors are loud, too. Hard to say if the noise is too much, but I don't hear anything immediately abnormal.
Looking at your fresh topics, you need DiCE+VIDA to really take care of this car.
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Sounds fine to me on a crappy cell phone speaker pressed into my ear. Only in the presence of the running engine can one truly shoot from the hip at an audible diagnosis.
In decent health, they tend to make a lot of “sewing machine” -type sounds, which come mainly from what VTL mentioned. Yours sounds a lot like it likes running. That can be a chore on a 2.4T!
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Put the handle of a long screwdriver against you ear to zero in on the sound.
Or open the oil fill cap and pour in Some motor oil. If if goes quiet it's the valve train.
Yours sounds similar to mine.
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 46 times
Post by darylrobert »
Sounds pretty normal, that whirling noise is your serp belt. remove it to check its not the timing belt.
