Car stalls. Hard start. MAF questions
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Post by surfbug1 »
Hello,
98 Volvo V70 Glt
Car will shut off at lights and when idling. Just plain cuts out, no sputtering just drops off and engine stops
Tried the (disconnect the MAF trick) and she starts right up.
In fact I can drive with the MAF disconnected, but I know that's bad.
Any way to clean the MAF? or should I just go to a junkyard and buy another to replace it.
I'm not buying new unless needed, car has 245k miles.
Thoughts or guidence please.....
Thanks!
Al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Assuming it's a heated wire MAF and not the other technology that Toyota/Lexus used for awhile you should be able to clean it. They sell "MAF Cleaner", but I usually use contact cleaner for electronics. I suspect it's the same stuff.
It would be interesting to see what the PCM/ECM sees. When I had one go bad on my truck, it was reading way too low, like a 2 instead of a 9. I don't recall what the units were.... mass/time, possibly.]
EDIT: turns out Volvos use "heated film" MAFs and those are not easily cleaned and often said to be not able to be cleaned. My GM MAF is a heated wire, or possibly cold wire design, which is easily cleaned.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
ThaddeusTheBold
Year and Model: 1999 S70 T5
Been thanked: 10 times
Post by ThaddeusTheBold »
Contact cleaner is not the same as MAF cleaner. If you use contact cleaner on the heated wire element of your MAF, you will destroy it.
Ask me how I know..... ugh
Has thanked: 1610 times
Been thanked: 4065 times
You want pure hexanes and heptanes to clean a MAF, after which you will continue to seek the problem
454cid
Post by 454cid »
ThaddeusTheBold wrote: 25 Mar 2022, 12:02 Contact cleaner is not the same as MAF cleaner. If you use contact cleaner on the heated wire element of your MAF, you will destroy it.
I haven't had a problem with it. I've never ever purchased MAF cleaner. Maybe Volvo MAFs are different somehow? I've never cleaned my Volvo MAF, just my GM Delphi MAF.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
CRC makes a heptane based MAF contact cleaner. I used it once about 10 years ago on my '97 855's MAF and it caused no apparent harm.
I don't know if the '98 has the same automatic idle control valve as the '97, but if it does it might be worth while to clean it out.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
abscate wrote: 25 Mar 2022, 15:37 You want pure hexanes and heptanes to clean a MAF, after which you will continue to seek the problem
This. MAF cleaner is really good for selling MAF cleaner. Not much else. The MAF is almost always just shot, unless e.g. you can see junk on it. I'd get a junkyard MAF. If you can't find one PM me I may have one.
IAC is the same on a 98 and 97, jreed's idea to clean it is a good one.
surfbug1
Post by surfbug1 »
jreed wrote: 26 Mar 2022, 06:40 CRC makes a heptane based MAF contact cleaner. I used it once about 10 years ago on my '97 855's MAF and it caused no apparent harm.
Thanks ! I clean d the MAF, didn't make a difference.
How do I clean the idle control valve?
I will start searching, but if you have any ideas/steps/advice that would help!
Al
Ping me!
:D
surfbug1
Post by surfbug1 »
Here is more info
When car stall, it just drops out. Can be hot or cold.
And on every startup , even if hot or cold, the car does this:
First try
The engine will catch at 700 rpms, then stall
Second try
Engine will catch at 400 rpm then stall....
I keep the starter enganged, the key full on, and the engine will then catch at 900 rpm and then run fine.
And it happens every time. Even if I just start the car and it's running fine. If I shut the car down, it will have to be started like the above procedure shows
Also, when driving at highway speeds, the engine will drop out, and then come back on in about 5 seconds. (Moving 60 mph prolly starts it up again)
Tried to read obd codes, my port is dead. I check fuse #5 under the hood, it's fine and I even replaced it to be sure .
So, maybe next easy thing to do is clean the IAC.
I cleaned the MAF sensor, and no difference.
Thank u for the help
Al
Ping me!
:D
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Maf or fuel delivery(fuel pump,filter,fuel pump relay).
But...if it runs good with Maf disconnected and not stalling or cutting out...it's bad Maf.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
