Running a ground wire for a trunk subwoofer
wrybread
Year and Model: 1998 S70 GLT
Has thanked: 15 times
Been thanked: 15 times
Post by wrybread »
I'm getting materials together to install a subwoofer in the trunk of my s70 (not a body panel shaking sub, just something to add a bit of bass), and I'm wondering if people think I should run a ground wire from the battery, or if I can tap into the chassis ground somewhere? I vaguely remember reading that chassis ground isn't done anymore, but maybe that was wrong, or maybe 1998 predates "anymore".
Thoughts on finding a good ground spot in the trunk? And what you'd use to tap into it?
Carlo the Nautic Blue 1998 S70 GLT
Previously Diego the 2000 S70, now has a blown head gasket and is awaiting the coroner
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Just ground it to a chasis somewhere in the trunk.
Scrub paint a bit to reveal bare metal and bolt it down.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
misha wrote: 30 Mar 2022, 12:51 Just ground it to a chasis somewhere in the trunk.
I second this, and would add that it would be a great idea to clean/re-new the grounds in the engine compartment while you're at it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
When I did the fuel pump wiring mod on mine, I used an existing grounding point under the rear seats. It's under the lower part of the seat, you need to lift some insulation padding to see it.
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
My sub is grounded in the trunk area (or was it under the backseat?). I think the ground wire to the battery is for the nerdy audiophile group that almost got extinct 15 years ago.
Don't forget there is a really nice rubber grommet underneath the brake master cylinder where you can run your +12V wire through the firewall.
1996 855 R,
2010 V70 D5,
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
wrybread wrote: 30 Mar 2022, 10:21 I'm getting materials together to install a subwoofer in the trunk of my s70 (not a body panel shaking sub, just something to add a bit of bass), and I'm wondering if people think I should run a ground wire from the battery, or if I can tap into the chassis ground somewhere? I vaguely remember reading that chassis ground isn't done anymore, but maybe that was wrong, or maybe 1998 predates "anymore".
Hi there,
Steel is not a great conductor not as good as wire grade copper which is fairly pure copper, but because the good conduction of current depends not only on the material but also on the cross sectional area that means if you increase the cross sectional area you can get a huge tub of butter to conduct well :-)
Seriously the chassis will have a large cross sectional area so it should work well for a ground, which actually acts as one wire of the speaker that has to conduct current to the speaker. If there is some strange circumstance that does not work out well on your car you can always go back and replace it with a heavy gauge copper wire so nothing lost on trying.
If your speaker draws 120 watts peak then that would be 10 amps peak (engine not running), which is not really that high really. A 14 AWG wire would handle that well, or if you want to go to a 12 AWG wire that means even less drop. We can calculate the voltage drop and power loss for each gauge of wire if you like no problem.
Has thanked: 1609 times
Been thanked: 4063 times
M6 bolts holding down the fuel pump cover would make nice ground points
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
MrAl wrote: 11 Apr 2022, 09:15 if you increase the cross sectional area you can get a huge tub of butter to conduct well :-)
And THAT's why they call you Mr Amp!
wrybread
Post by wrybread »
Cassis ground for the win! I even got fancy and used a terminal block in case I install another amp. For no good reason in hindsight, would have been easy enough to add more grounding points. Every time I browse the r/CarAV reddit I wind up buying some other gizmo I probably didn't need, ha.
Now if only I could figure out which of these wires in the rear lighting harness is the reverse lamp for my backup camera... That's been oddly hard to google.
It’s the one with 12 volts on it in reverse gear, with the ignition on…
