1998 V70 GLT - the turbo was leaking oil into the intake, so I took the turbo off and had it rebuilt. Now that's all back together, I get codes for the O2 sensors - sensor 1 slow response, and rear O2 sensor compensation. What's a good test to determine if the O2 sensors are bad, or if the catalytic converter is damaged from all the burnt oil that was going through it? I haven't driven it much since the turbo was replaced, so will getting some highway time help?
Thanks!
How do I tell the difference between a bad O2 sensor and a damaged catalytic converter?
crazytooguy
- Year and Model: 1997 S90
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Measure temperature of exhaust pipe before n after cat. If cat is working the trmperature after the cat is significantly higher.
BMW 540i 2002
S70 Base 2000
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Really? How come? Does the catalyzation process heat uo the exhaust fumes?kallekula wrote: 02 Apr 2022, 11:25 Measure temperature of exhaust pipe before n after cat. If cat is working the trmperature after the cat is significantly higher.
I always thought that if the temperature in front of the cat is significantly higher than behind the cat it indicates a clogged cat because the exhaus gases can't be pushed through the cat fast enough.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I had the slow response code recently on my '97 855 GLT and replacing the front O2 sensor resolved it. In your case since you had to remove the turbo I'd recommend double checking the intake system for leaks if you haven't already done that... if you have an intake leak it could cause the slow response code.
Some additional info here: https://www.matthewsvolvosite.com/forum ... hp?t=28754
Cats rarely go bad so if the OXS are over 100k old, do them first. Unless you were blowing pathological oil smoke I doubt the cat is bad
- Has thanked: 2199 times
And you would likely get that lovely smell from the tail pipe as well!
- kallekula
The material inside the cat gets very hot. Exhaust gasses passing through a functioning cat picks up that heat.Clemens wrote: 03 Apr 2022, 02:38Really? How come? Does the catalyzation process heat uo the exhaust fumes?kallekula wrote: 02 Apr 2022, 11:25 Measure temperature of exhaust pipe before n after cat. If cat is working the trmperature after the cat is significantly higher.
BMW 540i 2002
S70 Base 2000
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
I did kill a cat when i did modify ECU pretty quickly if that ever happened and tried do tuning on my previous car.
Insides of cat did make 180 degree turn. Otherwise tuning is fun thing.
To back to thing there is good videos how diagnose these issues. Like measuring pressure before and after.. sometimes you can swap first and second O2 sensors to try if fault moves to other one.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I drove around with a turbo oil leak for over a year with no lingering catalytic effects. The was over 10 years ago. I had a 007 style smoke screen everytime I floored it. The volvo version of coal rolling.
- 4897 Views
Last post by MadeInJapan
- 12 Replies
- 3144 Views
Last post by siamblue
- 2805 Views
Last post by mkc1
- 810 Views
Last post by Florida Wheel
- 1299 Views
Last post by mrbrian200
