Relay location for coolant fan motor
Hello, thanks for the add. Just bought a 2007 xc70 for my son. Fan motor turns on as soon as the car turns on. Runs constantly while car is on. High winding noise. Trying to figure out where the relay is for this fan - thinking that’s the culprit.
!! Thanks.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
The “relay” per se is the Controller that is integral to the fan assembly. There is a large gauge wire that powers the fan and a small gauge purple wire that runs from the ECU and provides the triggering signal when either the AC or engine coolant temp calls for it. There is a single coolant temp sensor that provides temp info to trigger the fan AND it provides info to the temp gauge. So if the gauge is showing a reasonable temp level then it’s likely the sensor is OK.
- 4390 Views
Last post by WA-Boater
- 1523 Views
Last post by Ferazi
- 724 Views
Last post by loveMy850
- 3161 Views
Last post by bmdubya1198
- 2645 Views
Last post by prwood
