So, out of the blue, the AT in my 96 R blew up. So the manual swap is happening soon.
A friend of mine is parting out a 93 10V, and I could get the tranny, flex plate, pedal assembly and what else for free.
Can I make a 93 M56 work in a 96? I want to keep cruise control, ABS and AC.
I think to remember that there os a problem with the speed sensor between pre 95 and 96 up cars.
Thanks, Clemens
93 M56 in 96R?
- Has thanked: 2856 times
- Been thanked: 1332 times
- Nevada1906
- Year and Model: 1995 850 Turbo
- Been thanked: 30 times
Make sure you get all the miscellaneous clutch bits like the master cylinder, fluid line, throwout bearing, etc.
They add up quick, and FCP won't even buy you dinner first.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Robert Spinner (posting as rspi here) is doing one right now in California.
I agree with the advice to get all the bits form the donor car, especially the trim pieces around the shifter - and of course, be careful, all that plastic is brittle.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
I would probably get the whole parts car, he needs it gone. So all the small parts should be there.
Does anyone know if the 20V trannies will take the torque of of a Turbo?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Same M56 used in the T5 at 250 ft lbs or so.
- Clemens
Good to know. I'd imagine that as well, but some Germans said they are different. I doubt it, though.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Guys swap in manuals because they're stronger than the not-bad 4sp autos. And 5.809 times more fun.
- Clemens
yeah, totally. My 94 T5M is way more fun than the 96R. But this is about to change. While at it, I will replace the RMS and drop in a Quaife. It's now or never.
On the earlier M56s the clutch slave cylinder is accessible from outside, so no need to put a new one in, right?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- foggydogg
Robert has one in his 850R wagon, and I don't think he is especially kind to the car. I predict you will be fine.
