No matter what position the light switch is in, the high beams do not work. Thy do not work in the flash position (one forward with the stalk) or in the steady position. I see the blue high-beam light come on on the dash, and I can hear the relay clicking. At first they seemed to work intermittently, but now they are not working at all. If I move the stalk forwards and backwards a bunch of times, the high beams do seem to come on about 1/30 times. Once they are on, they do not turn off by themselves. I have also tested both bulbs with a multimeter, and they are fine.
How would I fix this?
High beams not working.
- Been thanked: 504 times
Get a used stalk from junk yard ($10) or ebay ($25) and use it to test.
Common problem is in the stalk.
Easy job, once the upper cover is lifted up, only 2 Torx screws.
Tons of info in forum...
iamhives
- Year and Model: 2018 V90 T5 R design
- Has thanked: 1 time
- Been thanked: 6 times
In addition to the other suggestions which are probably more likely it still could be the relay despite it making a noise. Even though its clicking maybe its not making a good contact.
- 875 Views
- 832 Views
Last post by ilcaa
- 508 Views
Last post by MoVolvos
- 1383 Views
Last post by chiefpontiac
- 1490 Views
