I need a manual transmission from an 850. Ideas?
ThaddeusTheBold
Year and Model: 1999 S70 T5
Been thanked: 10 times
Post by ThaddeusTheBold »
Hi again,
I am looking for a manual transmission (transaxle) from an 850 for the electric conversion of my V70.
I have the traction motor and my motor controller is almost complete. I'd like to source the transaxle and mate it to the motor for development and testing. I'd like to get everything working right and then just drop the whole completed motor/transaxle unit into the car. I'm not having much luck finding a transmission, though.
Ideas?
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 85 times
Post by hausmeister »
Pretty sure you can find a manual in sweden or europe. Wrecking/salvage etc, I see some on ebay for 300-500€ checking quickly.
Not sure if that helps you though.
850 T5-R '95 auto Image
Has thanked: 1611 times
Been thanked: 4071 times
You don’t need a gas motor transmission with an electric motor. Just a final drive
ThaddeusTheBold
Yes you do, if you are using a DC motor with advanced/clocked brushes.
I’m not familiar with that. What does the torque curve look like?
ThaddeusTheBold
Flat. Total torque from bottom end to top end. Most people just start out in 2d or 3rd and drive the car around like that.
From what I'm told, You advance the brushes when you are going to overvolt the motor and over rev it because the flux 'smears' and you need to adjust the pulse timing. But by advancing the brushes, you lose the ability to reverse the motor by flipping polarity. So I need a transmission so I can have reverse. I also might like a top gear for highway work, although this is going to be a running-around-the-city errand car.
Couldn’t you return the brushes to a static mode for reverse? Putting in a lossy transmission into an electric is a “real toilet paper on the shoe “ solution.
What efficiency gain do you get with brush advance? Trans and diff losses are 15% or so.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
abscate wrote: 27 Apr 2022, 04:46 Couldn’t you return the brushes to a static mode for reverse? Putting in a lossy transmission into an electric is a “real toilet paper on the shoe “ solution.
Reverse gear simplifies the electronics greatly I'm told. I recently watched a video where one of the electric conversion/parts companies built a race car (Beemer, I think) that they took to Pikes Peak. They were letting a guy demo it on the street and it was insanely fast/powerful. The guy was just giddy driving it. They bolted two motors together to a GM Powerglide transmisson, and reverse gear was one of the reasons they sited...much simpler electronics.
Edit:
I didn't realize till now how old these videos are.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
Regardless of the use of the any gears besides reverse, you still need the differential and mating parts to the drive axles. Sourcing a manual trans that works with the chassis sounds like a good solution.
Keep us updated. This is interesting.
ThaddeusTheBold
Motor controller. Yes, simplicity in my electronics are a necessity. :D
