Vacillating Transmission Fluid Levels
miriamsully
Year and Model: 2006 s60
Post by miriamsully »
My transmission fluid shows as being right where it should be when I first check it, but if I check it a second time it's an inch and a half further up the stick. I've been checking it with my car level and running, and I've been waiting until my car is all warmed up, but this happens every time I check the fluid level. Any idea what would cause that?
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 18 times
Been thanked: 33 times
Post by ignatz »
My 02 does the same, but reads in the lower cold range when first pulled out. After I clean the dip stick and reinsert it, it shows all the way to the top. I check it only after driving for at least 30 minutes and sitting perfectly level.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
miriamsully wrote: 26 Apr 2022, 20:50 My transmission fluid shows as being right where it should be when I first check it, but if I check it a second time it's an inch and a half further up the stick. I've been checking it with my car level and running, and I've been waiting until my car is all warmed up, but this happens every time I check the fluid level. Any idea what would cause that?
Air pressure buildup in transmission's oil sump. You want to check the level on the dipstick when the pressure is relieved. If it's 1.5 inches higher than indicated marks - it's definitely overfilled.
