Hi All,
I've got an XC90 2011 D5244T18 engine.
Looking to replace my camshaft position sensor after seeing fault code: ecm-3000 camshaft position (CMP) sensor. Can anyone advise where this sensor is located? having trouble finding a diagram online.
The reason for pursuing this is I'm having intermittent cold start problems where it won't start at all first try, then instantly starts 2nd turn.
Also, have various swirl actuator fault codes (ecm-1850 through to 1890), but surely that doesn't affect cold starting?
Would appreciate comments and feedback. Thanks
Camshaft Position Sensor Location ?
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
VIDA has two entries for ECM-3000 on a D5244T18, CPS faulty signal and CPS missing signal. In both cases the suggestion is made about wiring (corrosion, connections) or a faulty sensor. Possible Source line mentions a damaged mass air flow sensor but suggest you might also be seeing a corresponding ECM -134x or -135x code under that circumstance.
Fault trace for resolution is wire tracing- sensor pin 1 to ECM pin #A10 (GND), sensor pin 2 to ECM pin #A33 (Signal), and sensor pin 3 to ECM pin #A7 (5V supply).
- 14406 Views
- 2629 Views
Last post by Luzanov345
- 1421 Views
Last post by cn90
- 542 Views
Last post by jackissocool
- 779 Views
Last post by cBobs94850T
