96 850 Turbo: Codes P0302 P1310 - problem ONLY during idle
insession
Year and Model: 1996 850
Been thanked: 2 times
Post by insession »
As of late, I've gotten codes P0302 P1310 at the same time. The car runs and accelerates just fine while driving, turbo kicks in fine too. The rough running only shows up while idling, and in gear. It's smooth in P and N, but jerky while idling in gear (with foot on brake). I delete the codes, but thus far they've come back.
A visual inspection doesn't show any cracked/loose hoses. Cables/plugs/rotor/cap are pretty new.
Does this point straight to the IAC? I've cleaned it a few years ago, it had been gunked up. Any pointers greatly appreciated.
Peter
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Misfires can still happen with new wires. Pull the wires off of the distributer 1 at a time and check for corrosion. If clean, then pull the distributor cap off and check for any signs of wear or corrosion.
insession
Post by insession »
Thanks ZionXIX - will look. But wouldn't a straight-up misfire show during driving/acceleration as well, not just during idling?
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
it could, but not necessarily. Usually I've had bad idle or cutouts under high rpms, but betwenn 2000 and 3000 all of my p80s ran smooth even with well worn ignition parts.
1996 855 R,
2010 V70 D5,
insession
Post by insession »
Copy. Will look into it tomorrow or the next day and report back.
insession
Post by insession »
No corrosion on wire ends at distributor, but enough dark/rough areas on rotor and all cylinder brass points. Gave it all a good clean and will see if/when codes may show again. Idle upon reassembly is calm and steady, have not driven it yet.
It's possible that I didn't get high enough quality parts last I replaced all the plugs/wires/cap/rotor. I did get NGK (54120) RC-EUX023 Plugs, Bosch 03371 Distributor Cap, Champion RC8WYPB3 (9801) Iridium plugs, and a Standard Motor Products GB-368T Distributor Rotor.
Peter
Has thanked: 2197 times
Been thanked: 1850 times
Parts suppliers of many of the parts can give variable outcomes. NGK wires can work or not. I have read more with issues fitting them but then you only hear from those with issues! :D I would only recommend Bougicord (Volvo)
I wouldn't use Champion plugs, only Bosch, OE Volvo or possibly NGK. The most important think is for them to be gaped correctly.
Plugs are not always gaped consistently or correctly for Volvos. I can never remember what the gap is, I think it is 0.028"
Rotor arm only Bosch brand from a reputable supplier. Too many knock-offs out there these days.
Hopefully your adjustments with what you have work well now!
Neil
454cid
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
scot850 wrote: 30 Apr 2022, 10:56
Rotor arm? I've never heard that combination of terms before... are you speaking of ignition?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Gap is critical for turbo engines...it must be 0.026-0.028.
Spark plugs...Volvo (set of 5) for turbo engines,NGK iridium properly gapped or cheap copper Bosch or NGK properly gapped..nothing in between and nothing fancy...since it will not run properly with anything else.
Cap & rotor MUST be Bosch,spark plug wires Bougicord.
You might want to read this:
http://volvospeed.com/vs_forum/topic/96 ... /#comments
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
insession
Post by insession »
Thanks guys!
I imagine Neill meant distributor rotor when he said 'arm'. And yes, that will be my next replacement with a Bosch one.
Plugs had been gapped at 0.028 by me recently.
Peter
