Hi guys I have a 2000 Volvo S70 t5 48k
The problem is poor acceleration I’ve had a few of these cars in the past and they’re very quick this car feels like it starts out in second or third gear I hooked up the OBD and got code p1631
I would appreciate some help guys please
2000 Volvo s70 t5 48k sluggish acceleration off the line Topic is solved
Johnthevolvoking82
- Year and Model: 1996 Volvo 859
- Has thanked: 1611 times
- Been thanked: 4075 times
Hello fellow NYr
That 1631 code is a communication error between engine and transmission management modules, or computers. Your AUTEL code reader always get the right codes but doesn’t always get the right text.
The car will then stick the transmission into “limp mode” which feels like you are starting in 2 or 3 gear, because you are
Doing exactly that!
Inspect wiring and perhaps reseat the modules if you are comfortable with that
Doing exactly that!
- Has thanked: 2212 times
Your ABS light is not on by any chance? That can throw out the speed sensor signal and can cause trans issues/limp mode.
The P0442 is a minor Evap leak but that should not affect your car's running. Probably the 'J' hose at the carbon filter under the RH rear passenger seat under the floor. Either that or the gas cap seal being bad.
Like abscate says, corrosion can occur with the contacts on the TCU and ECU. When this happened on one of my cars it threw many error messages including the speed sensor signal. I had the dealer diagnose the issue for me and they removed the TCU and ECU, cleaned all the contacts, reset the system and car was good after that.
Johnthevolvoking82
How do I reset the modules and should I replace the gas pedel
No for the gas pedal replacement. Try clearing codes first and see if they come back
Johnthevolvoking82
I reset the codes and then car had hard time starting back up but code came back I also disconnected the Meg terminal and also touched it to poss and still code came back
Re-read your post.
So you have 2 codes, the first one is not clear on the picture the P1631, as well as the P0442.
As your car is the 2000 model year it is more likely the ETM unit that is failing. For some reason I thought your car was a 1998!?
As abscate says, I would agree that it is unlikely to be the throttle pedal is the issue. Like anything it is possible but I do think unlikely to cause the car to start up in 2nd or 3rd gear.
For the car to want to start in a higher gear the TCM has to be seeing a load condition that would tell it to start in 'winter' mode. Does your car have the 4 speed auto trans, and does it have the WINTER button in front of the gear shift?
Johnthevolvoking82
I sold the car couldn’t deal with it anymore
Ooof. Someone just scored a great deal
- 2656 Views
Last post by sleddriver
- 582 Views
Last post by Ozark Lee
- 2821 Views
Last post by FLXC90
- 1774 Views
Last post by Dan79
- 223 Views
Last post by 02V70
