Hey guys. First post here. Just bought a 2011 C30. It's been about 8 hours owning the car and already in love with it. I think this one has some electrical gremlins though...
Car is parked & locked but the hazard lights are blinking. I read some posts saying it might be a faulty siren module due to battery acid spilling on it so i i went ahead and pulled the siren fuse underneath the dashboard (fuse 56) and no luck... Lost keyfob functionality and hazards are still blinking.
I tested the siren with the panic button on the keyfob and it DOES work... very loud and clear. So now i'm thinking that it's the actual hazard switch (in between the A/C vents) that is faulty and causing the lights to blink, even when parked and locked.
I have also tried unlocking and relocking the car and it does nothing. Hazard lights keep blinking.
Does anyone know how to remove the hazard switch in between the A/C vents above the waterfall? I want to try unplugging it to see if they can at least stop blinking and not drain the battery.
Hazard Lights Blinking When Locked! Hazard Switch Removal / Replacement?
- aewoodhouse
- Year and Model: 2007 V70R
- Been thanked: 7 times
The hazard light button is integrated with the vents and it comes out as one piece; both vents with the button in between. Use a plastic pry tool and try to pull it out evenly. It can require a bit of force - which can be unsettling when dealing with the often fragile interior parts, but worse case scenario, you can always get another one at a pick and pull yard or ebay for not too much $. Once you pull it out, the hazard button is the only plug on the back side.
2007 V70R
2004 XC70
Past:
2009 C30
1998 S70 - Turquoise 5 speed
2000 XC70
2004 XC70
Past:
2009 C30
2000 XC70
- 847 Views
Last post by jalbs
- 482 Views
Last post by Sveedy
- 14 Replies
- 4168 Views
Last post by RickHaleParker
- 4189 Views
Last post by foresthump
- 2822 Views
Last post by 850forum
