Front Driveshaft Removal V70 XC
Front Driveshaft and CV Replacement Tutorial
1. Prop up the car with 2 jack stands on each side 2. Remove the wheel and the bolt that hold the axle in from the outside of the wheel (on the cv side). 3. Loosen up the clip that hold the brake line (will give the wheel more play) 4. Loosen the two control arms? where they connect to the brake caliper assembly.
Share this
One Reply to “Front Driveshaft Removal V70 XC”
