Ignition Switch Electrical Fix – 1999 V70
MVS Forums moderator abscate explains how to do this very quick fix, and lists the telltale signs that it’s due: “Typical symptoms – erratic ABS, CEL STS or other lights – often coming on after a bump in the road. May or may not be controlled by thumping steering column.
Elapsed time from hood open to closed, 10 minutes.”
Tools needed
  • Small Screwdriver, flat – easing open plastic case around steering wheel
  • 11 mm wrench for negative battery terminal
  • Torx 20 bit
  • Torx 25 bit
  • 4 inch extender
  • Replacement switch
1999 V70 T5 Ignition Switch replacement with Pictures
