Bulb Replacement Guide: Neo-Wedge Bulbs
This is auxiliary data supporting  Volvo Bulb Guide and Cross-Reference topic in the Volvo forum.
Neo-Wedge Bulbs
Sorted by volts, base, then wattage for ease of comparison.
JKL Lamp # Volt Watt Base* Lumens Hours Length
CNW1-CW44 12 V 0.48 W NW4.6 1.13 10k 9mm
CNW1-7219 ** 12 V 0.72 W NW4.6 1.89 16k 9mm
DNW1-DW44 12 V 0.48 W NW6 1.13 10k 14mm
ENW2-EW44 12 V 0.48 W NW6 1.13 10k 16.5mm
DNW1-DW46 12 V 0.72 W NW6 2.01 10k 14mm
ENW1-EW44 12 V 0.48 W NW8 1.13 10k 14.5mm
CNW1-CW1240 14 V 0.56 W NW4.6 1.51 16k 9mm
CNW1-23 14 V 0.56 W NW4.6 1.89 16k 9mm
CNW1-811 14 V 0.91 W NW4.6 1.89 16k 9mm
CNW1-CW11 14 V 0.91 W NW4.6 2.51 10k 9mm
DNW1-DW48 14 V 0.56 W NW6 1.89 10k 16mm
ENW2-EW48 14 V 0.56 W NW6 1.89 16k 16.5mm
DNW1-DW21 14 V 0.84 W NW6 2.51 10k 14mm
DNW1-DW07 14 V 1.12 W NW6 3.77 15k 14mm
ENW2-EW07 14 V 1.12 W NW6 3.77 15k 16.5mm
DNW1-DW10 14 V 1.40 W NW6 6.29 10k 14mm
ENW2-EW10 14 V 1.40 W NW6 6.29 10k 16.5mm
ENW2-EW33 14 V 1.75 W NW6 9.00 10k 16.5mm
ENW2-EW37 14 V 1.75 W NW6 9.00 10k 16.5mm
ENW2-EW89 14 V 1.96 W NW6 11.00 14k 16.5mm
EW87 14 V 1.96 W NW6 12.00 7k DC 15mm
ENW1-EW48 14 V 0.56 W NW8 1.89 16k 14.5mm
ENW1-EW07 14 V 1.12 W NW8 3.77 15k 14.5mm
ENW1-EW10 14 V 1.40 W NW8 6.29 10k 14.5mm
ENW1-EW33 14 V 1.75 W NW8 9.00 10k 14.5mm
ENW1-EW87 14 V 1.96 W NW8 12.00 7k 14.5mm
* Bases: NW4.6, NW6, NW8
** As far back as 2001, many have suggested using Radio Shack 272-1092 “12V Microlamps” or any 7219 bulb and carefully re-wiring it into the old base. Others have suggested just buying Honda 35505-S84-N01 which already has the base attached. For even brightness, best to replace all at the same time on the radio and ECC, keeping working ones as spares.
Share this
