Bulb Lookup Tables: Seven-, Eight- & Nine-Digit Volvo Bulbs
This is auxiliary data supporting  Volvo Bulb Guide and Cross-Reference topic in the Volvo forum.
Less common Volvo bulbs
Less info available than some other bulb types. Often for switch and accessory illumination.
Volvo# Volts Watts Base ECE (non) Osram# Lumens Info
3524511 12 V 1.5 W 2752MF? Instruments bulb OSR_2439488A
3545170 12 V 1.2 W Instrument/ashtray bulb
6846118 12 V 27 W PGJ13 (90°) H27W/2 881 477 lm
8620487 12 V 60 W P20d HB3A 9005XS 1860 lm long life
9128743 12 V W blue holder (for 1.2w bulb)
9139568 12 V W S/V40
9148906 12 V W NW4.6 17mm T Switch bulb, 17mm T, white
9148907 12 V W
9148908 12 V W NW4.6 8.5mm T Hazard switch, grey
9166336 12 V W Non-“E”CC bulb, S70+
9203529 12 V W see 987790
9438777 85 V 35 W P32d-3 D2R 66250 2800 lm Xenon HID; see 989833
9454848 12 V W NW6 23mm T ECC bulb, S70+
9472109 12 V 3 W W3W 22 lm bulb with black holder
9472110 12 V 2 W W2W bulb with grey holder
9472339 12 V 3 W “high rating”; see 9472110
30612503 12 V W Heat control switch bulb, S40
30612504 12 V W 64122MF? Heat control switch bulb
30618412 12 V W Instruments bulb
30618695 12 V W Hazard bulb S/V40
30634737 12 V W see 987790
30640524 12 V 21 W BAW9s HY21W 300 lm
30640764 12 V 10 W Interior light
30618695 12 V W NW Hazard switch bulb
30715617 12 V 3 W W3W soldered to blue socket
30739356 12 V W NW4.6 (white) 9mm T Heat controls bulb, 9459780
30739357 12 V W Ignition switch bulb
30739358 12 V W NW (grey) Heat controls bulb, 9459780
30752175 12 V W Control light
30763954 85 V 35 W PK32d-2 D1S 66140 3200 lm
30822412 12 V W Instrument bulb
30864008 12 V W Instrument bulb
31213995 12 V 24 W PGU20-4 PY24W 300 lm
31290593 42 V 35 W PK32d-5 D3S 66340 3200 lm
31290607 12 V 24 W PGU20-4 PY24W “Silver Vision” of 31213995
Share this
