SAS Delete/Removal Tutorial (No CEL!)
IVIUSTANG » Yes, this does get rid of the P0410 code completely. erikv11 » The ECU doesn’t check the pump directly, it checks the relay and the solenoid…
Let’s talk Code P0171 On startup, regardless of the weather, the S70 will let out a puff of white smoke. The Check Engine light is on and throwing…
