How to Change Coolant and Avoid Destroying Your Engine in Modern Volvos
Want To Know How to Change Coolant and Avoid Destroying Your Engine? If you’re looking to change the coolant (antifreeze) on your modern Volvo, slow your roll! There’s…
I also flushed the cooling system with newe Prestone. Pretty easy: 1.13 mm wrench for the engine drain plug (located just above the driveshaft, on the right and rear side of the engine)…
