1999 S80 2.9 Front End Clunking Noise
Do you have clunking you can feel under your brake foot at low speeds and in turns? You can add two large “o-rings” to take up any slack in the bushing of the subframe and eliminate the clunking. You will need two o-rings and two new bolts. Part numbers for the parts to fix this are listed in the thread.
