DIY 1997 Volvo 850 Roll-Over Valve Hose Replacement
Roll Over Valve Hose Replacement -
The past few times I’ve tried to fill up the gas tank the pump keeps shutting off after just a few seconds, no matter how slow you try to pump in the fuel. It took me a while to finally get the tank full. This is new behavior for this car. As part of the diagnosis, I decided to check out the roll over valve to make sure that it was allowing the vapor from the tank to pass through to the charcoal canister during fueling.
