1 Star2 Stars3 Stars4 Stars5 Stars (No Ratings Yet)
Loading...
Troubleshooting Low Boost
Posted on
Underboost is a condition that can be caused by several issues including:
  1. Bad TCV
  2. Bad Turbocharger
  3. Failed boost sensor (for models that have them)
  4. ECU seeing overboost and cutting back until reset and condition remedied
  5. Failed MAF (for ecu’s that use the MAF to determine boost pressure)
  6. Failed atmospheric sensor ( again for those that use it)
Less boost after wastegate adjustment
Comments
There are no comments. Use this if you just want to comment and don't need or expect a response. No registration required.
You may use these HTML tags and attributes:
<a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <del datetime=""> <em> <i> <q cite=""> <s> <strike> <strong>
