Volvo 850 cermamic brakes or OEM?
Q “I am about to redo brakes and rotors on front and rear… I was wondering if the ceramic pads are worth the little extra they cost. I should i stick to the oem volvo pads which i believe are semi metallic. Are cross drilled rotors an additional plus ? Are they worth the extra for an every day driver or are they just a pad eater?”
A “Cross drilled rotors are a cosmetic upgrade only, and most available are of poor quality. Stick with a good quality OEM rotor.”
Volvo 850 ceramic brakes or oem?
2 Replies to “Volvo 850 cermamic brakes or OEM?”
  1. Definitely go for the ceramic brake pads. In my experience with the track and high speed driving, organic brakes pads can handle 1 good high speed stop before they fade. Semimetallics on 302mm rotors are good for 2-3 high speed stops before fade sets in. Ceramic pads on 302mm rotors are good for 4-5 stops before fade starts. Also the ceramics seem to squeal less than the semimetallics.
