question about 1993 850 Topic is solved
This topic is in the MVS Volvo Repair Database » Volvo Headliner Rear Clips for 850 Sedan, V70
coco
Post by coco »
here's what's been happening lately to my 93 850. the seat warmers and power side mirrors stopped working. when i back down my driveway and then when i first accelerate, the battery light comes on. there's a bit of hesitation and then the car kicks in fine. now, when you start up, the air conditioning and recycling lights flash on and then stop. i guess these are all separate problems but they're happening all at once. any ideas?
AutoX47
Year and Model:
Post by AutoX47 »
coco wrote:here's what's been happening lately to my 93 850. the seat warmers and power side mirrors stopped working. when i back down my driveway and then when i first accelerate, the battery light comes on. there's a bit of hesitation and then the car kicks in fine. now, when you start up, the air conditioning and recycling lights flash on and then stop. i guess these are all separate problems but they're happening all at once. any ideas?
weak altenator probably
Andrew Zizzo - ypc-inc.com
1996 Volvo 850 Turbo
Volvord
Year and Model:
Post by Volvord »
The symptoms you describe can be caused by many things and it would be imposable to provide an accurate diagnosis without further investigations. The problem could be as simple as a slipping alternator belt, dirty or loose battery contacts, or loose grounds on the engine. The problem could also be more serious including a faulty battery, alternator, regulator or grounding / wiring trouble in the harness.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
