Front turn signals wont blink Topic is solved
marcusantonus2
Post by marcusantonus2 »
Hi,
My front two turn signals seem to be stuck on the ON position, so when i want to use them they wont blink. I looked at the bulbs and the light filament ( both the parking and turning) are on at all times. It makes the front lighting brighter but its not safe because on comming traffic doesnt get the turn signal. The rear signals work but the fronts dont. I checked for the flasher but it seems that its all in one in the hazard module. Or is it? Any feed back welcome.
Thanx
:shock:
marcusantonus2
Well,
I looks like the bulbs were placed in the wrong way. I used a electral tester to see if there was power on when the parking lights were set on. Then I checked to see if there was power when signals were working. I noticed that one side was working and the other not. I checked the fuses..in the engine compartment, and #24 fuse lf.signal was burnt out. Replaced the fuses and made sure the bulbs were placed correctly and I was finished. Thanks anyway.
M :lol:
