I recently purchased a 1998 volvo s70. Every time I put the radio on , the words "OFF" appears. What are the steps to enter the code into the radio in order for it to work? Please help.
sharmella
car radio Topic is solved
- Tsquared
- Year and Model: 11 C30
In the owners maunel you should have a card with the radio code on it.
The radio will only display EEE or OFF when the wrong code has been entered and the radio is locked depending on model - this is due to the battery being disconnected and the incorrect radio code being entered 3 times. You will neet to reset the radio. To do this the radio has to be on for either 2 or 4 hours - see the manual for your model. If you got the code from a card from Volvo, and it didn't work, then the radio has been changed or it has been reset by the dealer and your current code is invalid. You will have to pull the radio and find the serial & model number, and get Volvo to look up the code for that radio or the dealer may be able to lookup the radio code via vin# from Volvo. The dealer can reset the radio and enter a new code. When the radio is "ready" to accept an unlock code the display will say "codE". You will need this code if your battery is ever disconnected.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Dr. Seuss
so what exactly does one do when entering the audio systems number?
does one hold any buttons? what type of power should be available ( should the key be in accessories position or car on)?
please inform. 8D
please inform. 8D
Eraser
We own a 1998 Volvo V70 T5 Wagon. The Battery was disconnected for service and now with the code from the dealer we cannot get the radio out
of CODE mode. Dealers have informed me they cannot reset the radio and
recode it. Is this true or are they trying to get us to buy a new radio?
Rob
Rob
- Has thanked: 2656 times
- Been thanked: 1248 times
I've never heard of a radio being re-coded. This doesn't mean it can't happen
Call another dealer and ask for your radio's code.
This whole radio code thing is so much more trouble than it's ever been worth to Volvo owners... it's designed to keep theives away. But what theif would steal a (double height mind you) Volvo radio? The young punks want cool aftermarket radios like Alpine/Blaupunkt/Sony etc. I know, I was once one
- Tsquared
A Volvo radio can be re-coded. While my 850 was in warrenty the battery was disconnected during service and the code did not work. The dealer removed the head unit and plugged it into a computer where they re-programed the code. The radio serial number is required to pull the code from Volvo.
Find another dealer - one that is interested in helping you, not helping themselves to your $$.
The radio code should be in the dealers database provided by Volvo. When a radio is re-coded the dealer submitts an update to the database so that if it is needed in the future any other dealer with access to the database can pull the code with the serial number of the radio.
'11 C30 T5
asquared
To Tsquared,
My radio is showing the OFF message as well. You mention that it needs to be on for 2 to 4 hours before it may be reset. Does this mean that the radio needs to have power flowing to it or that the car needs to be on with the radio on at the same time for that period?
- Tsquared
The radio needs to be on with the car on (I am not sure if will work in the ACC key position) for the 2 to 4 hour period. I have driven arround for a week the time that I put in the old code an had to reset it. The other option would be to visit the local Volvo delaership and get it rest.
'11 C30 T5
Liz
My radio didn't work after getting a new battery. And I didn't have the code as I bought the car used.
Any Volvo dealership can get the code; they need your VIN number and the radio serial number. The radio itself pops out pretty easily and the serial number is right on top. Volvo of N. America won't release the code directly to the consumer; only to an authorized dealership. It's a four digit code.
I had the unfortunate experience of being told I had to buy a new radio "because there's no code for it". The dealership wanted me to spend $230.00 then and there. Fortunately, I ain't that dumb.
I drove to ANOTHER dealership who had the code in two minutes flat and at no charge.
Talk about music to your ears.
Keep that code in a safe place; I also ended up writing it on the radio itself. Nobody wants to steal this radio, believe me, and it is incredibly easy to just pop it out of the dash.
Beware of any dealer that gives you a BS line about no codes or recoding. They are trying to steal your $$$$.
