bulb
- Tsquared
- Year and Model: 11 C30
You have a bulb that the filliment is broken but it will still make contact until you hit a bump or apply the brakes. It will eventually go totally out.
You can test for it by cranking the car, and with the light on, tap on the the lights around the car. It may flicker or go out. It also may not show up. Also have someone press tha brakes and check these as well.
Good Luck
T
Good Luck
T
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
- 4568 Views
Last post by adrian22
- 3875 Views
Last post by silentcircuit
