850/v70/S70 Wagon Sunroof Interchange...confirmed 3509020 Topic is solved
BeachWagon
Year and Model: 2002 V70
Has thanked: 7 times
Post by BeachWagon »
Might be a tall order, but does anybody have a good reliable list of other Volvos with the same sunroof assembly as my 96 850R wagon? My sunroof is stuck in place. Turning the screw under the light enclosure yields no movement whatsoever, it is completely stuck.
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Any 850 sunroof should work. I think they're all the same. I do wonder if the sedan 850 sunroof are the same?
BeachWagon
That's what I'm wondering. Or maybe ANY p80???
Has thanked: 1506 times
Been thanked: 3818 times
Should be able to sort out by putting model years into Volvo parts website like
https://www.volvopartswebstore.com/prod ... 43308.html
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
This should give you a clue.
The Sunroof frame is part number 3509020.
Applications:
Volvo 850 2.3L 5 cylinder A/T FWD R Sedan 1997
Volvo 850 2.3L 5 cylinder A/T FWD R Wagon 1997
Volvo 850 2.3L 5 cylinder A/T FWD T-5 Sedan 1997
Volvo 850 2.3L 5 cylinder A/T FWD T-5 Wagon 1997
Volvo 850 2.3L 5 cylinder A/T R Sedan 1996
Volvo 850 2.3L 5 cylinder A/T R Wagon 1996
Volvo 850 2.3L 5 cylinder A/T T-5R Sedan 1995
Volvo 850 2.3L 5 cylinder A/T T-5R Wagon 1995
Volvo 850 2.3L 5 cylinder A/T Turbo Sedan 1994, 1995, 1996
Volvo 850 2.3L 5 cylinder A/T Turbo Wagon 1994, 1995, 1996
Volvo 850 2.3L 5 cylinder M/T FWD R Sedan 1997
Volvo 850 2.3L 5 cylinder M/T FWD R Wagon 1997
Volvo 850 2.3L 5 cylinder M/T Turbo Sedan 1994
Volvo 850 2.3L 5 cylinder M/T Turbo Wagon 1994
Volvo 850 2.4L 5 cylinder A/T Base Sedan 1994, 1995, 1996
Volvo 850 2.4L 5 cylinder A/T Base Wagon 1994, 1995, 1996
Volvo 850 2.4L 5 cylinder A/T FWD Base Sedan 1997
Volvo 850 2.4L 5 cylinder A/T FWD Base Wagon 1997
Volvo 850 2.4L 5 cylinder A/T FWD GLT Sedan 1997
Volvo 850 2.4L 5 cylinder A/T FWD GLT Wagon 1997
Volvo 850 2.4L 5 cylinder A/T GLT Sedan 1993, 1994, 1995, 1996
Volvo 850 2.4L 5 cylinder A/T GLT Wagon 1995, 1996
Volvo 850 2.4L 5 cylinder M/T Base Sedan 1994, 1995, 1996
Volvo 850 2.4L 5 cylinder M/T Base Wagon 1994, 1995, 1996
Volvo 850 2.4L 5 cylinder M/T FWD Base Sedan 1997
Volvo 850 2.4L 5 cylinder M/T FWD Base Wagon 1997
Volvo 850 2.4L 5 cylinder M/T FWD GLT Sedan 1997
Volvo 850 2.4L 5 cylinder M/T FWD GLT Wagon 1997
Volvo 850 2.4L 5 cylinder M/T GLT Sedan 1993, 1994, 1995, 1996
Volvo 850 2.4L 5 cylinder M/T GLT Wagon 1995, 1996
Volvo C70 2.3L 5 cylinder A/T Base Coupe 1998, 1999
Volvo C70 2.3L 5 cylinder M/T Base Coupe 1998, 1999
Volvo C70 2.4L 5 cylinder A/T Base Coupe 1998, 1999
Volvo C70 2.4L 5 cylinder M/T Base Coupe 1998, 1999
Volvo S70 2.3L 5 cylinder A/T FWD T5 Sedan 1999, 2000
Volvo S70 2.3L 5 cylinder A/T T5 Sedan 1998
Volvo S70 2.3L 5 cylinder M/T FWD T5 Sedan 1999, 2000
Volvo S70 2.3L 5 cylinder M/T T5 Sedan 1998
Volvo S70 2.4L 5 cylinder A/T AWD AWD Sedan 1999, 2000
Volvo S70 2.4L 5 cylinder A/T Base Sedan 1998
Volvo S70 2.4L 5 cylinder A/T FWD Base Sedan 1999, 2000
Volvo S70 2.4L 5 cylinder A/T FWD GLT SE Sedan 2000
Volvo S70 2.4L 5 cylinder A/T FWD GLT Sedan 1999, 2000
Volvo S70 2.4L 5 cylinder A/T GLT Sedan 1998
Volvo S70 2.4L 5 cylinder M/T Base Sedan 1998
Volvo S70 2.4L 5 cylinder M/T FWD Base Sedan 1999, 2000
Volvo S70 2.4L 5 cylinder M/T FWD GLT SE Sedan 2000
Volvo S70 2.4L 5 cylinder M/T FWD GLT Sedan 1999, 2000
Volvo S70 2.4L 5 cylinder M/T GLT Sedan 1998
Volvo V70 2.3L 5 cylinder A/T AWD R AWD Wagon 1999, 2000
Volvo V70 2.3L 5 cylinder A/T AWD R Wagon 1998
Volvo V70 2.3L 5 cylinder A/T FWD T5 Wagon 1998, 1999, 2000
Volvo V70 2.3L 5 cylinder M/T FWD T5 Wagon 1998, 1999, 2000
Volvo V70 2.4L 5 cylinder A/T AWD AWD Wagon 1998, 1999
Volvo V70 2.4L 5 cylinder A/T AWD X/C AWD SE Wagon 2000
Volvo V70 2.4L 5 cylinder A/T AWD X/C AWD Wagon 1998, 1999, 2000
Volvo V70 2.4L 5 cylinder A/T FWD Base Wagon 1998, 1999, 2000
Volvo V70 2.4L 5 cylinder A/T FWD GLT SE Wagon 2000
Volvo V70 2.4L 5 cylinder A/T FWD GLT Wagon 1998, 1999, 2000
Volvo V70 2.4L 5 cylinder M/T FWD Base Wagon 1998, 1999, 2000
Volvo V70 2.4L 5 cylinder M/T FWD GLT SE Wagon 2000
Volvo V70 2.4L 5 cylinder M/T FWD GLT Wagon 1998, 1999, 2000
Has thanked: 292 times
Been thanked: 765 times
This kind of sunroof swap has been done many times: all P80 are the same, sedan or wagon.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Thanks Rick
Added part number to thread title.
Even fits the “bastards”
:D
BeachWagon
My 850R sure is a bastard....at least right now haha. I'm on the home stretch of a head gasket/valve job and sunroof WAS next on the to-do. Now I may have a warped valve cover soooooo yay!
Thanks for all the info everyone. Makes my life a bit easier.
