Volvo SC-900 Radio head question? Topic is solved
Has thanked: 1850 times
Been thanked: 1712 times
I picked up 2 x SC-900's at PnP yesterday. One is junk as it looks like it has been sitting wet and has serious corrosion on the motherboard.
The other looks ok and has cleaned up nicely. I can't test it until I get the Code for it.
However, there is a small piece of electricians tape stuck over one of the LED's (?) on the front. Any of you radio whizzo's know what the purpose of this red light is and why someone would put tape over it?
SC-900 with tape on front
SC-900 with tape removed
I am planning to return the other unit to PnP in the next couple of days as well as the Dolby unit (also rusted and loose components inside), so if this is a fault that is not easily repaired I will junk this one as well. It is a Volvo re-worked unit.
Thanks,
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
I believe that it’s the IR sensor
for the optional remote control.
If that is the case, any idea why someone would cover it with a bit of tape?
BEJinFbk
Post by BEJinFbk »
That’s a really good question.
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
Hy,
It seems that the round plastic cover is missing... ?
It is there Manovlov. Just bad picture. Just got code from dealer so will try it later and see what happens.
Thanks guys,
manovlov
Post by manovlov »
A little sponge bath and he'll be good as new. Well done !
