While pulling my injectors on ‘98 S70 GLT some months ago, I bent the little rail that appears to be a gasket for the injectors. I bent the metal back in place, seated the injectors back in and everything was fine for hundreds of miles.
Today, I smelled gasoline wherein I figured out that it was coming from this injector. I’m onside of the road and want to get back home— 10 minutes or so driving to get back home.
Does this gasket prevent gas from coming out of the injectors? Is it safe to drive back home with the potential of gas leaking?
I’ll go to a junkyard tomorrow and pull a gasket off of another car.
How important is this gasket? Topic is solved
1998s70GLT
- Has thanked: 14 times
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
It's not so much a gasket, as it actually does secure the injectors and the fuel input line into the fuel rail. I lost one of the screws once and that alone was enough to have the fuel input line leak a lot of gas all over the engine while I was driving on the highway at high speed/heat. Yours looks bent enough to have the injector not all the way in. It's definitely not safe when you have gas leaking from there. That being said, I was possibly driving for up to an hour before I recognized my car was leaking and I didn't explode. Mine was pretty heavy and spraying all over the place, but I ended up successfully using zip ties to get me to where I was going with no leaking.
Personally, would I risk the 10 min drive to get home with a minor leak knowing what I know? Probably, but only if I could stop the leak somehow with a zip tie or something. Safest answer is to not drive it.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- RickHaleParker
- Been thanked: 958 times
Lay it out on a flat straight edge and tap it back true with a small hammer.
1998s70GLT
I seated the injector in snug, ran the car for ~10 minutes to make sure there was no leak and then I drove back home. I got back home and noticed that there is still no leak. Tomorrow I’ll pull a new rail and replace it.
When replacing that rail, can I just remove the three T25 bolts or di I have to pull the injectors first?
FlyingVolvo
If you just have the fuel rail out like you did, it's super easy with just the 3 bolts. Not sure if I'm misunderstanding you, but you can't remove the injectors from the fuel rail without removing that metal plate.1998s70GLT wrote: ↑17 Nov 2020, 16:00 I seated the injector in snug, ran the car for ~10 minutes to make sure there was no leak and then I drove back home. I got back home and noticed that there is still no leak. Tomorrow I’ll pull a new rail and replace it.
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 1850 times
- Been thanked: 1712 times
Like the guys have said. The metal 'comb' is just a retainer. It locks into the slots on the injectors to prevent them sliding out under pressure.
As suggested remove the metal, and gently hammer it flat again. What seals the injector is the injector 'O' ring. With the comb bent it allows the injector to slide out enough to weep gas out.
If the comb in the area of the injector is soft, it may straighten but bend again in use. Careful use of a hammer should help harden the metal again as it is straightened.
Good Luck!
Good Luck!
- Has thanked: 927 times
- Been thanked: 1000 times
+1scot850 wrote: ↑17 Nov 2020, 17:06 Like the guys have said. The metal 'comb' is just a retainer. It locks into the slots on the injectors to prevent them sliding out under pressure.
Good Luck!
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
So did all of the 850's have that retainer ? I know mine doesn't so I am wondering. Seems like a good idea.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 1505 times
- Been thanked: 3818 times
I think all cars retain the fuel injectors with some sort of clamp, your might be missing Sveedy
Yikes
Yikes
- Sveedy
Well I found another post here that said that cars with the orange injectors did not have that retainer. Cars with blues or whites did.
I'm going out to the junkyard today to look at a recent arrival so I'm going to check this out. Seems like the two bolts hold the fuel rail down so I don't see how an injector could pop out anyway.
1999 V70 GLT
1999 V70 GLT
