- Has thanked: 304 times
- Been thanked: 517 times
I think that's how it goes, and it's aggravated by a hot lean mixture, which just torches the valve. I agree with the theory on oil reside retaining heat too, since that seems to be a common theme on these cars when they burn valves.
RedBrickCollector
- Year and Model: 1997 850 T-5 Wagon
- Has thanked: 40 times
- Been thanked: 28 times
From what I know watching too much of a certain kind of video youtube barely tolerates
Hot, high pressure gasses have an erosion effect, and any type of debris in the valve face would cause a break in the seal where combustion gasses would leak through. These gasses would slightly wear away at the metal as the combustion byproducts act like microscopic abrasives. The heat escaping into areas with significantly more oxygen than the cylinder would also make the metals much more reactive, not quite actual combustion, but scorching some off like the oxycetylene torch mentioned.
Now that could be barely a scratch the first time, but now it has an imperfect seal, and the next combustion finds that exact same spot over and over until you burn through the valve entirely.
I agree with the others that the valve stem seal is the root cause but I don't think it's the residue holding heat
I could very well be wrong haha
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
- Has thanked: 927 times
- Been thanked: 1000 times
Seems to me this is like the erosion of early rocket nozzles that were not of good enough material.
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
So here's something else to chew on. My procedure for cleaning the head is copious amounts of throttle body cleaner (4 cans on this head), followed by a soak in hot water with detergent. Then another shot of throttle cleaner if needed, and finally WD40. When I lifted the head up to take it for its bath, I noticed this left behind. Yep. A valve seal just fell off of the guide. I don't think they're supposed to do that
So at least in this case, faulty seals were the culprit.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 1850 times
- Been thanked: 1710 times
So is that where the expression, " My Volvo goes like a rocket!" comes from?
Neil
Neil
- Sveedy
Windows decided to stop working today. Took the master switch apart, and yuck...
Cleaned, reinstalled and windows work again, though one of the rears seems a little finicky.
1999 V70 GLT
1999 V70 GLT
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Found the pieces to the cargo area shade so I can epoxy them back together in the days to come.
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 68 times
I got the blue V70XC started after waffling on it for a year....and it's still making a horrific tapping sound, same as it was when I took the head off. I believed that was due to the RTV on the exhaust gaskets blowing out from a backfire, but maybe this car has a cracked exhaust manifold? Exhaust is separated in the middle behind the cat, but it seems to be coming from the engine bay and exhaust manifold area. Would have been nice to catch while the head was off, but I'm going to hook up the smoke machine when I get home.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
