Youtube links:
Teardown part 5
P80 manual shifter cable 1
P80 manual shifter cable 2
V70 engine drop sneak peek
I forgot to disconnect the brake lines and fuel line. WOW how durable they are!!! See below.
As you can see, I managed to remove the spaceship ONLY by bending it upward before spinning it.
I had already loosened the 12mm nut on steering rack to drop it out. I thought that was all that was required. OH BOY I tried dropping it out and that one bolt held the entire weight of the subframe. WOW THATS A STRONG BOLT!!! But turned out the paired bolt had to be removed completely.
On the head, I noticed a difference in the carbon build up on the intake valves. The three on the passenger side and farthest driver side were all fairly similar. But second from driver side was kinda oily. Im assuming that was a cause of the misfire it had? However one of the far driver side valves had a strange gray crusty on it. Strange.
