manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
Hy guys,
I've replaced the rubbers seals to allow to open the passenger dfront door from inside.
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
I tried to start it aaand no crank.
How normal is it for a dead battery after 3 weeks parked?
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Today I did a compression and leak down test on the V50 (bought for cheap with known motor issues).
Need to confirm the numbers on the donor motor from Erie Volvo, but look much better with 50k fewer miles.
07 V50 T5 AWD M66 ~146k miles
Has thanked: 1497 times
Been thanked: 3809 times
smacknab wrote: 21 Sep 2025, 13:04 Today I did a compression and leak down test on the V50 (bought for cheap with known motor issues).
Let me know if you need that engine crane/leveler bar again
Chieber
Year and Model: 1998 v70
Has thanked: 45 times
Been thanked: 29 times
Post by Chieber »
abscate wrote: 20 Sep 2025, 03:37
Chieber wrote: 18 Sep 2025, 03:19 Junkyard time! Fun with a buttplug 😂
That’s a beautiful brick floor for a junkyard!
I remember a discussion about having a brick floor or just solid ground.
So I looked up the type of soil of which this city is build on. Seems like the foundation is a mix of clay, peat, and sand. So it’s ever slightly sinking.
The floor is probably paved for easy maintenance and no stuck parts or cars on the ground.
1/2 a shitbox V70 1998 2.5 NA
Chieber
Post by Chieber »
If it works, it works! Fixing the broken pin of the cup holder.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
RedBrickCollector wrote: 21 Sep 2025, 10:56 I tried to start it aaand no crank.
If you have the alarm set or some other drain on the battery, 3 weeks to no start is not surprising. This happens to my 2001 Mercedes all the time is I don't drive it.
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
A full suspension refresh is underway for my 850 wagon. I had a productive weekend and got half the garage cleaned out to make room for Scarlett.
She's sat there untouched for a year. I dropped a new battery in and she started right up.
Big order from FCP arrived
You northern boys are gonna hate how easy it was to start disassembling the from suspension. Not a single drop of penetrating oil or heat was used here.
I haven't touched the brakes on this car since purchase in 2006. Ive put about 100,000 miles on her in that time. I have no idea if these are factory brake pads.
Every conceivable boot is torn. CV axles, ball joints. Sway bar endlinks, power steering boots, all of it.
This list of "while you're in there" parts is growing rapidly.
We’ve got our fair share of low rust stuff, too….
:D
DennisCA
Year and Model: 1996 850
Been thanked: 59 times
Post by DennisCA »
I've sprayed high build primer on the tailgate and sanded it down again. Probably gonna repeat this process once more but with a thin coat before going to the base coat.
Dynamic action shot!
I'm thinking of buying some infrared heaters to use as curing lamps because spray painting has to be done at whatever the outdoor temp is right now, and it's mostly around 10-14 C which is too low. Doesn't have time to dry between coats even if I give it 10 minutes. I do not have a real paint booth so I am dependent on the whims of the weather.
Regarding the "slot" or groove under the tailgate window, that's a real rust accumulator. Here's a tip I got:
I got this tip to fill it up with some suitable sealant instead. Doesn't look that good on the pictures, and this guy has basically sealed up all the trim pieces on his car (mk.1 V70) like this, claims it stops the panels rusting behind. Function over form he says.
Filling up that groove with something like this is the plan. Not sure what, some kind of material is suitable. Sikaflex perhaps or maybe seam sealer. I think perhaps with care one can get a pretty decent looking bead. Or maybe glue on a decorative strip to hide it.
