99' S70, 5-speed, Immobilizer Problem. End of the road for Matilda?
Has thanked: 1497 times
Been thanked: 3809 times
Re: 99' S70, 5-speed, Immobilizer Problem. End of the road for Matilda?
We have it another hour today
Reproduced symptoms. Scanner reads VIN from CDM, and parameters from dash show up and change as toggled
Engine temperature reported as -40C bottom of range. Noted from wiring that the ECT reports directly from the ECM so that also points to a non responsive ECM (not necessarily non-working)
We swapped in Jane Bonds ECM, for a 2000 NA m56….same symptoms
We checked the CANBUS Aline’s for, CDM to ECM for continuity , all good
Then I noticed the main relay was not pulling in. 850 LPT comfirmed this.
We jumped it with a paper clip, no joy.
Then the relay started pulling in again?????????
Could that be the intermittent ???
Has thanked: 1834 times
Been thanked: 1709 times
Try this link for P80 S70 NA wiring diagrams:
https://portal-diagnostov.com/en/root/r ... -diagrams/
scot850 wrote: 04 Oct 2025, 10:12 Try this link for P80 S70 NA wiring diagrams:
Behind paywall. $20 to get pdf
Sorry about that, strangely when I tried first time it went straight in. Should have copied the files. I'll look some more and try to extract from Vida. I seem to recall I had issues accessing wiring diagrams last time I tried.
Ok, these 2 have access to the diagrams. The first has a free 3 day trial. and the 2nd is the Norwegian Volvo Club:
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://forum.vccn.no/dokumentasjon/Vol ... n_3_39.pdf
Note. Mathilda’s ETMclicks on power up but does not run the complete self-test I am used to.
Video here
viewtopic.php?p=632156&hilit=ETM+video#p632156
Moved Neil’s post….😊
Yup. that is not what it should be doing. The possible issues I am sure you have considered are:
1) ECU - I believe you have swapped in an alternate to see what happens. I assume you have the same result with that.
2) ETM - If you have not swapped that out, that is where I would be looking to or a wiring issue to the ETM from the ECU.
Swapped in both Shaggs and Jane’s ECU and no communication to either. We are going to try Mathilda’s ECU in a good running car.
Here is the harness tracing diagram , eeeks
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
EEK is right.
Good thing I happen to have a complete stripped out DENSO harness in my garage….
Screenshot 2025-08-05 at 08.28.12.png (576.84 KiB) Viewed 64 times
