How to remove brake fluid reservoir screen?
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
On a 2000 V70, how do you remove the screen affixed to the fill neck of the brake fluid reservoir? Mine has some debris which I'd like to remove. Also, I'd like to do a fluid flush, so would like to suck out as much old fluid from the reservoir as possible before adding new. Thanks.
FireFox31
Has thanked: 1850 times
Been thanked: 1710 times
It should just un-clip. You may need a small screw driver to get under the edge.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 130 times
Post by 454cid »
What is the screen for? It's not a universal thing with all vehicles.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Keeps grit out of the brake fluid.
twooldvolvos
Year and Model: 1990 240
Has thanked: 2 times
Post by twooldvolvos »
I just spent about an hour trying carefully to get the screen out of my 2007 xc-70 reservoir. I was looking for a special lock or some trick. But no. You simply have to use a couple of small screw drivers and/or some needle nose pliers to get it out. You might think it is keyed when you look carefully at the mouth of the reservoir BUT IT IS NOT. Just pry and pull and the %$#%^#$ will come out. If you don't poke a hole in the screen you can reuse it. Otherwise screens are available at not much money. Experience is the best teacher.
I have had cars I have helped with that have had holes in the bottom of the screen to allow the fluid to be turkey baster removed. Some are missing altogether. Like you say, it is a swine to get out without damaging it. Why it could not have just been a drop in screen who knows?
