1993 850 coming from wrong port.
BigLib
- Year and Model: 1993 850
- Has thanked: 6 times
All of my codes are coming out of A3 but according to the charts none of the codes should come out of A3. It's this a problem?
- Has thanked: 1848 times
- Been thanked: 1710 times
Been a long time since I had a 93 850 with the engine bay diagnostic ports. I had to go to this video from Robert DIY. Perhaps this may help to answer your question:
- misha
- Has thanked: 152 times
- Been thanked: 402 times
A3 is diagnostic port for abs.
Engine codes should be read from A2(ecu) & A6 (ignition module).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
Are the codes you are getting plausible?
If they are, it's weird but at least you can work with them. The blinky box in my 94 T5 is funky too, some ports that should work simply don't have a metal socket and therefore don't respond at all, and not all codes seem to have numbers that should be created by the specific port in use.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
