Chaosrob 1999 v70R 601 save, Going to need a lot of parts, lot of help and do a lot of reading.. Topic is solved
chaosrob
Year and Model: 1999 v70R
Has thanked: 37 times
Been thanked: 15 times
Re: Chaosrob 1999 v70R 601 save, Going to need a lot of parts, lot of help and do a lot of reading..
Post by chaosrob »
I have a spare diff here from the 2000 parts car it's just redoing the work. I'm just whining
abscate wrote: 12 Nov 2025, 01:42 Patterson auto wrecking in Cohoc. PA - listed at ~ $300 delivered?
I also just remembered my Albany Crew has a 1999 XC upstate which in a holding pattern of either repair or part out. THats another source of parts potentially. Ill PM you.
Has thanked: 1497 times
Been thanked: 3809 times
That’s a fair whine. I had to drop my axle three times, the third time my Indy did it.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2650 times
Been thanked: 1240 times
Post by matthew1 »
chaosrob wrote: 12 Nov 2025, 13:52 I'm just whining
Would this be considered a... mechanical whine?
:lol: :lol: :roll: :?
Also -> Amazon link
Any diff failure on a Volvo is so rare , nobody tests these things for stuff like that. If you have had the clamshell down already, second time is a breeze.
chaosrob
Post by chaosrob »
I believe pathetic would be a more appropriate term. Maybe I will just manual swap it at the same time, probably not but maybe
matthew1 wrote: 12 Nov 2025, 15:05
chaosrob
Post by chaosrob »
Well I think we found the reason for the car being initially parked. Figured there had to be a reason, it's a doozy. It never even crossed my radar to check it prior to putting it back together and since the pump was bad I couldn't drive it prior to dropping the rear the first time. I am making a table to support it this time and just raising the car off of it on the lift and doing the work on the table rather than grunting it all over the place
abscate wrote: 12 Nov 2025, 17:54 Any diff failure on a Volvo is so rare , nobody tests these things for stuff like that. If you have had the clamshell down already, second time is a breeze.
matthew1
Site Admin
Post by matthew1 »
chaosrob wrote: 13 Nov 2025, 07:03 I believe pathetic would be a more appropriate term. Maybe I will just manual swap it at the same time, probably not but maybe
The situation is depressing, not to make fun of you, just looking for humor in it. The front gets most of the power, I can't remember the split but it's at least 60/40 favoring the front in normal driving. It's bad luck. FWIW it looks incredible with the wheels. You're putting in some Work. Hang in there.
I forgot this in my first post so here it is now:
Also -> Amazon link
chaosrob
Post by chaosrob »
I didn't take it for anything negative, all you can do is laugh. Just another hurdle
matthew1 wrote: 13 Nov 2025, 08:49
Differential whine…..seriously , this might be the first bad differential thread on MVS since at least 2013
chaosrob
Post by chaosrob »
I walked away from this for awhile as I had other pressing matters but finally got a few hours to mess with it today. I dropped the rear sub frame AGAIN and replaced the rear diff with the one from my parts 2000 that I stripped. The diff is nasty as it was a northern car but it did not make any noise and fluid looked good.Got it back up in the car. installed the VC and nothing makes noise now when turned. I still have the exhaust, wiring to reconnect, driveshaft to install, rear brakes and the interior to put back together so hopefully will have this rework done tomorrow and with any luck this portion will be behind me. After that it is the ignition switch and an alignment and on to the rest of the body.
I would like to flip a big old middle finger to the engineers who designed this rear diff setup. They really made what is typically a fairly quick and straight forward job incredibly labor intense.
